Occassionally, I hear a hissing sound from within the dashboard which seems to be coming from the air conditioning vents. Are there some motors that control the air flow from the vent as I have climate control is my car?
The sound is only there for 2 seconds and then would come back after a few minutes.
Most of the time I hear it while on the Motorway as the car is cruising and there is no music on etc. It is very faint but I am not sure if it is something serious as I am only a 2month old skyliner.
Thanks in advance
https://www.sau.com.au/forums/topic/83600-noise-from-dashboard/
There is a motor/actuator that opens/closes the vents when chaning 'modes' try it, change the mode from feet to face to top vent and listen closely (dont need to have engine running)
Yes, I thought it was the case but even when it is set to a single mode and I am not changing it, I can faintly hear the motors. I guess it's the climate control system opening and closing the vents to maintain the set temperature.
Thanks for that, I was just a bit worried that something might be wrong.
:D
I've got that problem in my r33. When i turn the car on the ticking noise starts coming from the dash(near climate control), and lasts for few seconds. Change the mode to feet and face it stops it... so it only does it when the mode is to face or the climate control is OFF. What should i look for?
  • 4 weeks later...
*BUMP*
My r33 does this also. When you turn the key to the 'ON' position it makes a clicking/ticking noise like TK TK TK TK for a few secs then stops.
My sisters bf tried telling me it was the fuel pump pumping fuel to the engine that was making the noise, but my mate and I decided it was something to do with the climate control (as it made the noise again if you turned the climate control off or changed settings etc).
Is it supposed to be audible (it is easy to hear)?
My r32 Does the same but very Rare
I have it on Face and it goes tick tick tick tick tick, Scared the shit outa me when I first heard it. To stop it I changed it to feet and it stoped, I think its the motor getting Jammed by something or its trying to go lower then it is able. But i know its not a good thing, If you can hear a whine yes it the vents doing there job shouldnt be overerly loud tho, Might need re-greasing.
Guys, the sound coming from the dash that sounds like little motors are normal. They control the set temp from the climate control. You will notice this sound when manually adjusting the temp on the climate control. This is not a problem.
The ticking noise comes from the winscreen demister vents. When the car or climate control system is turned on, it goes through a vent check. The connectors to the vents on top of the dash, aiming at the windscreen are known to dislodge and when they are activated to open/close the vents, it clicks. This is a problem and the only way to fix is to pull out the dash. This is not worthwhile fixing as after a while, it will dislodge again. This ticking sounds occurs in all Skylines I've been in...
Hope this helps. B)
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
