okay first
when i hop in the car first thing in the morning, turn the key around to where the dash lights light up. (not starting the car) I hear this whining/groaning noise, sounds like it's coming from the rear of the car.
second
when i try to start it it won't fire up. well it does, but it sputters then stops, does this three or four times of times. Once it started it fine.
Both only seem to happen in the morning then it's fine for the rest of the day.
Would it be fuel related or electrcal?
stock rb20de cefiro. cat back 2.5' zaust
https://www.sau.com.au/forums/topic/83608-couple-of-qs-guys/
When you say sputter do you mean idle badly?
Mine used to be the same. In the mornings it would sputter at the start except it didnt stop. I had to rev it once to get it to stop it from sputtering and then it was fine for the rest of the day.
A new set of spark plugs fixed it for me. When I looked at my old spark plugs, the tips were so corroded i was surprised the car ran at all.
that's something else i forgot to mention.
after getting it to start. go for a 10 min drive, pull up whack it into park(neutral), and the engine revs back and forth from 1000 rpm to 2500 rpm 5 or 6 times then settles down to idle round 1000rpm. :rolleyes:
sounds like some of it could be a fuelling problem, the load buzz u hear, do u hear it for bout 5 seconds and then it stops?
get it on the dyno and see what its doing, also get a service and tune done on it.
Yeah bout 5 secs.
gonna replace the timing belt next service, plus some of the gaskets. get it all done then.
def the fuel pump on its way out, try a general service and tune (i.e spark plugs leads blah blah, if it still does it, well then i dunno wot sort of condition your car is in, but get some contact cleaner, and go clean all the plugs out, by spraying the pins, plug and unplug them a few times to clean it all up. try this, i had todo this with heaps of stuff on my old vlt. Just to make sure every terminal is connecting properly.
Can only cancel things out, and hopefully its a cheaper one :rolleyes:
Also, the car chug off boost at all?
my r32 does this, turn ignition1 on, and u can hear a pump going, but my hicas light will flicker a bit when the engine is dead cold. pump turns off after 5 seconds. I just assumed its the hicas lines repressurising. also car doesnt chug off boost. had a 100K service done 4 months ago, usual stuff replaced, but not fuel pump.
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
