I've currently got some unknown (brand and heat range) platinums that were gapped to 0.8mm. Due to a poor tune I need to replace them before the retune. Been looking up the spark plug threads and I'm going to give the iridiums a shot.
~200kw RB25 so I've got my eyes set on the Denso IK20s or the NGK BKR6EIX(one heat range colder than recommended for GTS25t, and standard recommendations for GTT). Seems that most people have NGKs, I doubt there'd be much difference but interested in any comments from someone who has the Densos.
The NGK I've listed has a 0.8mm gap standard, whereas the Denso is 1.1mm - but I've read that due to the narrower centre electrode in the iridiums (NGK Iridiums have a 0.6mm centre opposed to the Denso 0.4mm) - a larger gap (hence better spark) should be possible with the Denso. Thoughts? Or should I just gap the Densos to 0.8mm?
Cheers
https://www.sau.com.au/forums/topic/83698-another-iridium-thread/
I dont think 0.2mm is going to make any difference into the quality of the spark considering copper plugs tips are 2.5mm. I tried my iridiums at the standard 1.1mm and it misfired running 20psi. I had to bring the gap down to .85 to stop the miss. I tried .9 and it still had a slight miss
  • 2 years later...
hey pplz...i just bought some spark plugs(NGK iridium BKR6EIX) and i've been reading abit about .8 and 1.1 gapped plugs, the guy at autobarn said they were gapped at .6 so i was just wondering if that is suitable for my nearly stock RB25DET running 7 and 10 psi...i've search and cant really find exactly what i want to know...
please PM if it's no trouble...thank you
Edited by 4doors13secs
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
