HERE IS A NISSAN SKYLINE R33 GTST RB25DET FRONT RADIATOR COLD AIR RAM PLATE. THIS PANEL IS DESIGNED TO STOP THE HOT AIR RISING FROM THE CONDENSOR AND RADIATOR. THIS UNIQUE ALLOY LIGHTWEIGHT PANEL IN VERY EASY TO INSTALL. YOU CAN HAVE THIS AIR RAM INSTALLED IN YOUR CAR WITHIN 5 MIN. LOOKS VERY NEAT AND HIDES ALL OF THE UGLY BITS LIKE THE THERMO FAN AND RADIATORS. THIS UNIT WILL FIT PERFECTLY INTO CARS WHICH HAVE NOT BEEN INVOLVED IN PREVIOUS FRONT END ACCIDENTS."
These are customly made from Aluminum panel.
upto 5 buyers --> $70 each
6 upto 10 --> $60 each
10 to 15 buyers --> $50 each.
will end 7 days from now. ( aug. 20 Sat )
plus $10 shipping anywhere.
no it doesn't affect the air intake at all via the snorkel.. it blocks the air so it can penetrate deeply into the radiator system..
simply more air goes to the radiator...and you can put the snorkel over the top of this panel with no worries.
I wish someone sold these for R32 gtst... hint hint
Free bump.
Yeah...will try and do that actually.
Just letting everybody knows that i have an aftermarket grill ( GTR grill ) and i have one of these in my car,.although not a perfect fit..but i made it fit..no cutting or drilling required just a little bending using both hands and turned out not a bad job at all..will post pix later.
Guest
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
