Hi people, due to some interest in this kit after it was withdrawn from the for sale section I have decided to repost it. All relevant information is posted below however if there is something that I have missed please do not hesitate to PM me.
Item: Blitz twin turbo kit
Kit includes:
• TURBOS 3KT- still unsure about AR however part number is 3070MGA611
• MANIFOLDS (Stainless steel)
• DUMP PIPE
• WASTEGATES (32 mm)
• OIL LINES
• FULL PIPING (For 32 GTR)
Car/ Engine: Suits R32 or R33 GTR
Item Condition: The kit is in perfect condition however one of the turbo’s needs to be reconditioned. The other turbo is in perfect condition there is no shaft play at all. All the manifolds and waste gates are perfect.
Reason for Selling:I want to get rid of the clutter in the garage.
Price and Payment Conditions: This kit was initially advertised at a price that was pretty low; as I had a lot of bills to pay. However as I am in no hurry to sell this kit I am asking for $2900 ono.
I will consider any reasonable offer but please keep in mind this is a full high mount 900ps twin turbo kit for a GTR. So please no ridiculous offers.
Extra Info: I'm not sure how much a rebuild will cost as I never needed to get a quote. I replaced this kit with another kit I had lying around.
Extra Info about the kit: The Turbo’s are KKK/Blitz 3KT high mount turbo’s, which are rated at 450ps each will make 900ps on twin set up. These turbo’s are more commonly used on Porsche 911 track cars. Able to be used for track or drag, these turbo’s can produce big end power with good response.
NO TIME WASTERS PLEASE
Pictures
Edited by manage13
Guys,
I was quoted between (approx) $800-$1200 (depending on workshop) for full rebuild per turbo for those that are interested in the kit. Just thought that might save a few people some time with some enquires.
Goodluck with the sale.
Mick
Any takers?
I would be more than happy to take it off your hands for no cost to YOU! haha I am sure it will look pretty in my engine bay manoj. you can come look at it anytime you want! :)
g/l with the sale mate, ppl would be crazy to not take you up on this!
  • 3 weeks later...
  • 1 month later...
can i get some more info on these please? i recently purchased some 2530s for my gtr, but if these are better, ill grab them, im only new to gtrs so ye, as much info as possible would be appreciated!!!!
thanks
  • 1 month later...
Is this the blitz K3 450R?
genuine blitz? Ball bearing version or not?
also
Far as I am aware it is the blitz kit! If memory serves me correct there is a Blitz marking on the wastegates. However I am unsure about the turbo. I will check first thing in the morning.
This is the non ball bearing version.
what cm is the rear housing
Not sure at all!
what is the turbo
t3?
Yes, the turbo mounts on to a t3 flange.
  • 1 month later...
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
