JUST WONDERING IF GTR AND GTST SPRINGS HAVE THE SAME SPRING
RATES AND RIDE HEIGHT,
ANYBODY FITTED GTR SPRINGS IN A GTST??
You are kidding right?
GTR's weigh ~200kgs more than a GTST, almost all of it carried by the front wheels.
The front spring rate on a GTST is around 3kg/mm, so the lower weight would mean around 66mm (200 kgs / 3 kg/mm) higher if you stuck GTR front springs in a GTST.
:D cheers :)
Edited by Sydneykid
FAIR ENOUGH THE RATE MAY BE HIGHER,
BUT IS THE HEIGHT THE SAME,
MAY SIT THE SAME HEIGHT WITH A HIGHER
SPRING RATE,
It's not simply springs, the shocks (mounts and spring seat heights) are different as well.
DO YOU KNOW ABOUT THE REAR?
Yes I know about the rear, what do you want to know?
Maybe I can simplify this a little bit, Nissan didn't want people to pinch bits of GTR's and use them on GTST's. That would deminish the value of buying a GTR, you wouldn't pay the extra $ if you could simply swap bits over easily. So Nissan DELIBERATELY made lots of stuff (the good bits) on GTR's different so they won't fit on GTS's.
My suggestion is to simply move on, there are better solutions to whatever it is you are trying to achieve.
:D cheers :)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
