Im flicking through my local messanger today (as you do) and noticed in the law and order section an article titled "police target number plates". Well after reading it, not surprisingly they have been using an automatic number plate recognition camera/computer that allows them to identify stolen/unregistered/defected vehicles for the past year or so but havent publicised it until now. That a quote along the lines of "its primary purpose is crime reduction" which i belive is a load of nonsense. More like primary purpose is to hunt down and re-defect vehicles when they see an import drive past.
Anyways, though i'd share that with you all.
https://www.sau.com.au/forums/topic/84380-my-theory-is-true/
states defected vehicles. But honestly, if you vehicles has been cleared of being "unroadworthy" surely they are going to target you anyways no matter if your car is defected or not. Its just those who has had a canary before will more than likely get it again since their plates are on the computers records as a defectable vehicle.
This happened to a certain cefiro driver I know in the city last weekend, except his car was still on defect so he shouldn't have been driving it anyway.
But the short of it is they punched in his plate number, saw the car was defected, started chasing him, he ran and got away. Didn't really matter though cause they already had his plate number. When he got home there was a nice message from the Adelaide cop shop waiting for him.
Bye bye lisence me thinks.
can u scan the artivle, or know where i can get a copy?
Most large libraries should keep copies of all the major rags, make a few calls, is there an Adelaide city library or something like that (i only know Melbournes).
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
    • The pinchweld is fine, even with a trolley jack, so long as you're not actually pushing on the pinchweld itself. More to the point, we shouldn't talk about lifting or supporting on the pinchweld, we should talk about using the sill "jacking points", which just happen to be adjacent to the pinchweld. I just have dense rubber blocks with grooves in them for each of the chassis stands and the trolley jack, that I use at the sill jacking points if/when I have to lift/support there. They put all the load onto the steel pad of the jacking point and not the pinchweld. As intended.
    • Makes sense.  I would do something different if I felt like there was a better option. Generally the only other area I'm happy to jack on is where I want to put the stand. The pinch weld is not an option for me for either the jack or stands, so very limited options overall.  Plus never having had an issue with doing this, has kinda reinforced in my mind that it's fine. I'd do it on any car without a second thought these days lol.
