Hey guys,
I'm organising some number plates for my freshly complianced R32GTR.
I'm getting some standard sized plates, but was wondering if anyone know what the legalities were concerning stick on plates for the front? I've seen cars with the stick on's driving around, and think it would be a good idea so I don't block airflow to the intercooler. I also don't want to be drilling holes in my bumper.
If anyone has any (reliable) information about this, that'd be great.
I've requested a copy of the number plate legislation from Transport SA, but I'd be really keen to know from ppl who have the stick on's if you've been hassled by the cops etc.
Cheers,
Alan ;)
https://www.sau.com.au/forums/topic/84491-number-plate/
Any number plate not manufactured by a Transport SA approved manufacturer (I think there's only 1 in SA) is 100% illegal.
I'ven been warned for plates before on a previous car, so I did some research. Basically only the ones they issue are ok.
https://www.sau.com.au/forums/topic/84491-number-plate/#findComment-1528997
Only plates made by an approved manufacturer comply with the requirements of the Motor Vehicles Act. The display of non-approved plates incurs the risk of a Traffic Infringement Notice and a fine.
Plates must be visible from the front and rear and must not be obscured by a tow ball, load, plastic cover, dirt build-up or any part of the vehicle’s bodywork. Operating a vehicle in this condition renders the driver liable to receiving a Traffic Infringement Notice.
Got this off their site for you.
Couldn't find a list of "approved manufacturers" though.
https://www.sau.com.au/forums/topic/84491-number-plate/#findComment-1532137
I received the actual legislation for this today as well.
Pretty much what you've found on the website.
So now we all *know* it's illegal, but is it worth taking the risk to do it?
What are the ramifications of a Traffic Infringement notice? Fine? Demerit points?? Defect and Regency inspection?
https://www.sau.com.au/forums/topic/84491-number-plate/#findComment-1532492
The number plates transportsa issues don't fit. :(
On the R32 you are required to either bend the edges or trim them. Mine were trimmed neatly, obviously this is illegal but what else can we do?
I haven't been pinged for it as they are trimmed in such a manner its hard see unless you get down on your knees.
https://www.sau.com.au/forums/topic/84491-number-plate/#findComment-1535346
OK how about this question:
Do the authorities target cars with any form of personalised plates?
I currently have a set of premium plates on my MX-5 with some nice lucky numbers (superstitious asian stuff). I can simply transfer these across to my GTR if this is going to be an issue.
I did get a nice set of plates for the GTR tho, something related to "RB26" :(
https://www.sau.com.au/forums/topic/84491-number-plate/#findComment-1535403
well, the short answer is yes they do (as told to me by a forum member on NissanSilvia.com who is a copper), however I have distinctive peronalised plates and have not been targeted.
In fact for the extremely large amount of time I spend on the road, it is a wonder I never get pulled up. The only very few times I have been pulled over I brought it on myself and deserved it. However, I am not out cruising the hotspots Friday and Staurday nights .... that is just begging for trouble.
https://www.sau.com.au/forums/topic/84491-number-plate/#findComment-1535412
you can get transport SA approved plates for your push bike rack that goes on your towbar right... those little ones about half the size.
Correct me if I'm wrong, but the legislation doesn't mention size does it? Order 2 bike rack ones and use them :)
and put them on upside down....
I'm sure the legislation doesnt say anything about this...
https://www.sau.com.au/forums/topic/84491-number-plate/#findComment-1538674
I thought of that already, but unfortunately the legislation *does* specify the size of the plates.
You could always play dumb and do the "sorry officer, I didn't know" routine, but I doubt that's going to get you off more than once.
https://www.sau.com.au/forums/topic/84491-number-plate/#findComment-1538709
Not sure about the bike rack number plates, prob a bit of a flaw in the system there, but i'm sure they could get you on it somehow, best to just get the slim plates and not worry about it.
I couldn't be bothered paying $170 or what ever it is a year for custom plates so i ended up getting R and S series plates, think it was $70 for ever, and i can swap to what ever car i want. Works out well with the RB and SR.
https://www.sau.com.au/forums/topic/84491-number-plate/#findComment-1538712
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
