  • Replies 148
Kym thinks your all a bunch of panzy's and should git some ballz!
Yeah, i'll bring my girl along... why not ?
and as for takin pictures of the hottie's...there's no harm in it, and she doesn't mind....
I say "i'd hit it" to a good percentage of hotties i see walkin thru the shops with her right next to me!
... as long as I go home with her at the end of the day, it's all good... piss this "jewellry and chocolates" crap RIGHT OFF!
https://www.sau.com.au/forums/topic/8459-motorvation/page/5/#findComment-126478
Originally posted by puckish
PVA wrote---------------------------
aka camel toe
Don't you mean Camel Hoof ? If I saw a toe like bit down there I'd be concerned.. But then again what ever turns you on PVA.
umm..... puckis.... what do we do with ya!
unless you are still a virgin or you are not familiar with the term :lol:
either way that's classic :lol: :lol: :uh-huh:
I am speachless I am without speach!
cheers
Joe
https://www.sau.com.au/forums/topic/8459-motorvation/page/5/#findComment-126612
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
