  • Replies 148
Kym thinks your all a bunch of panzy's and should git some ballz!
Yeah, i'll bring my girl along... why not ?
and as for takin pictures of the hottie's...there's no harm in it, and she doesn't mind....
I say "i'd hit it" to a good percentage of hotties i see walkin thru the shops with her right next to me!
... as long as I go home with her at the end of the day, it's all good... piss this "jewellry and chocolates" crap RIGHT OFF!
https://www.sau.com.au/forums/topic/8459-motorvation/page/5/#findComment-126478
Originally posted by puckish
PVA wrote---------------------------
aka camel toe
Don't you mean Camel Hoof ? If I saw a toe like bit down there I'd be concerned.. But then again what ever turns you on PVA.
umm..... puckis.... what do we do with ya!
unless you are still a virgin or you are not familiar with the term :lol:
either way that's classic :lol: :lol: :uh-huh:
I am speachless I am without speach!
cheers
Joe
https://www.sau.com.au/forums/topic/8459-motorvation/page/5/#findComment-126612
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
