  • Replies 45
Posted Images
  • 1 year later...
Hey guys, just thought i would put my 2c's in lol
I have a rb24 in my 32, built with a N1 GTR crank and a rb24 tommie kit, thing is nuts, so much torque. I still need a new turbo thou, was running a 33 turbo on 18psi. Motor loved it, turbo didnt though when i took it up to 25psi, blew the rear wheel off and into a million peices. The motor made 220kw with some garat turbo that was to small and it had major boost insues, with the proper turbo it will pull 300-350kw atw no trouble. Bel Garage in sydney is to thank for my amazing motor. Need any info on it your best to ask them. www.belgarage.com.au
Edited by PetieR32
https://www.sau.com.au/forums/topic/8478-rb24/page/3/#findComment-4417975
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
