  • Replies 56
I don't think mr nissan would go to the trouble of including these rails just for cosmetic purposes as they are under the car where only your mechanic will see them :blink: ... sure they might not be true chassis rails like on ye olde cars, but they still are a structural part of the monocoque chassis and they look to add a lot of strength to the floor. I think the vehicle examination people are quite right to expect it to be in good condition and its a bit of a worry that chassis specialists dismiss a big dent like that so lightly. The other thing you need to make sure is that it hasn't twisted or bent the rest of the chassis.
its a 99% probablility the rail is spot welded and to remove it the easist thing to do is buy a special spot weld removing drill bit and drill them out. you are then left with a hole one side (in this case in the floor pan) that you can plug weld from inside the car to attach the new rail. The bigger problem i think you will have is getting access to the rail where it looks to sit inside another rail section and no doubt there will be access problems elsewhere. Unpicking spot welds is time consuming and fiddly work.
like someone else said 2k sounds about right to do the job properly....
Nice find with the chassis rails.
This is most definitely what I will be doing.
Have I attached a pic of the underside of a VL Commodore?
Its not suprising those things pop windscreens, lol. :blink:
http://www.skylinesaustralia.com/forums/in...pe=post&id=2157
Edited by Cubes
ok, i just talked to a guy that works with my wife, he used to be an automotive engineer and has some contacts that can weldup the new rails.
Im going to buy 3 rails from nissan, The crushed one and the 2 on either side of it.
I was picking at the rail yesterday and found it was roughly spot welded every 5 to 6 centermeters.
Ill remove the old rails, and get this guy to weld up the new ones.
Im waiting for him to get back to me.
Steve
here is a pic from the fast software
it show the bit thats crushed, and the 2 other bits that are damaged.
The one thats slightly damaged, il replace anyway cause that the bit that the gear box member bolts onto.
the smaller rail ill also change just to make it all look better.
ill keep you's updated.
steve
Edited by PHATR32
grafting in new rails is definately the way to go. you really need to make sure everything is perfectly sqaure though. I cannot stress this point enough.
best of luck, i will be interested to see how it goes, take plenty of pics.
ill keep yous posted, i just talked to the engineer guy and he said he'll be seeing his mate tonight. Hopefully this guy will be able to sort it and let me take pics too!
I assume getting the whole bar mig welded would be better than spot welding it??
i hope it turns out to be ok.
Steve
i just talked to nissan, the crushed bit is $141, the slightly damaged bit is $101.60 and the little one doesnt exist any more cause they dont make them!!!
so i guess i wont be changing the little one, which mean ill have to be carefull when removing it.
steve
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
