  • Replies 47
Hullo.... was wondering if you still have the steering wheel? I am after a standard steering wheel to pass registration. My momo one is 5mm too small to pass inspection.
Also after: genuine standard nissan R32 fuel pressure regulator
Standard front
Standard water spray/ windscreen wiper bottle
Back windscreen wiper (doesnt have to work)
Would appreciate any help! Thanks
reply either to this or email [email protected]
https://www.sau.com.au/forums/topic/85157-sold/page/2/#findComment-1544106
Ok, I've received a few questions about the HKS piping kit. Basically it is 3" stainless steel piping to replace all the factory pieces as pictured. The piping meets the intercooler inlet/outlet and is designed for a motor that DOES NOT run air flow metres.
The orange colour in my opinion doesn't look the greatest, but it's only a paint job away from being another colour. All the piping is in good condition with no dents. I will supply all needed clamps and joins etc..
https://www.sau.com.au/forums/topic/85157-sold/page/2/#findComment-1546639
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
