gday guys im lookin at r32 gts4s. ive found one and im just curious if you are able to switch between 4wd and rwd? i have a video of a r32 doing this and doing a rwd burnouit then 4wd takeoffs. ive also seen this advertised on a r32 gts4 as a cross over switch or sumthin. is it possible? is it recommended? cheers
https://www.sau.com.au/forums/topic/85220-gts4-question-can-u-have-it-as-a-rwd/
why?
if u want skids.. buy a gts-t.. if u want a nice solid launch, buy a GTS4 and leave it in 4WD.
the weight difference of the GTS4 will make it pointless having if you have any desire to run it in RWD for any reason regularly.
But yup, it can be done via a switch or fuse pull.
He is right
If you wanna be cool and do skips then don't buy a GTS4!
Mine came with a switch and i think i have used it like once maybe twice for the 18 months i have owned the car!
If you want 4WD grip get a GTS4 if you wanna go sideways get a GTSt.
End of story!
do what you want.
people always tell me to buy a rwd car when i say i run my GTR in RWD... but thats their opinon... i say do whatever you want.
but hey... i wana launch hard and i also want to drift and also do track work.... the GTR does well in all of em..
the gts4 is slightly slower then the gtst over the quartermile
To get the GTS4 in RWD simply either remove the fuse in the engine bay fuse box, or install a switch which cuts the circuit. I believe you have to reverse the car a bit once changing back to AWD. I am thinking of installing the switch in my GTS4 soon. With regard to a GTS4 not being suitable for sideways fun sometimes, this is simply incorrect, there is obviously more weight up front but all it takes is getting used to. Last time i checked a GTS4 weighs around 1480 Kg's with/without a driver (cant remember).
BUT if you plan on running around all the time in RWD it does seem quite pointless buying a GTS4, the only time i'd use RWD is for a bit of fun or perhaps a future drift meet - thats me though. End of day "up to you"....
Cheers,
Rhys
From Expierince on the issue does installing the switch damage or harm the AWD system in any way?
Also any further input into installing the switch, and any bad "side effects" on the GTS4 would help me and others. Certianly don't want to "hi-jack" your thread but it is an issue of query for me too, Thanks.
Edited by WhatBrake
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
    • @Stringycheese  Have you only gone to the one blue slip workshop?  There will be a heap of them where ever you live, good odds that the next place you go to will pass the car.  Unfortunately (or fortunately?) every blue slip / engineering workshop will be different and will be happy passing or failing different things - despite working from the same set of rules. It's kinda like 2 lawyers arguing over a piece of legislation, each saying their interpretation is correct. Might seem strange that this happens when it comes to getting a modified car passed, but this is very much a thing. A big part of the game is finding an engineer / workshop that is on the same page as you.
    • Bah. I daily mine. ~60km per work day, 10-12 thousand km per year. What's the point of having a dirty old Datto and leaving it in the shed. It needs to be driven and enjoyed while the govco allows us to do so. It will only be a few years before we're forbidden to even start up internal combustion engines.
    • Judging by that spring perch and the normal looking spring on it - not a coilover. Well.... it is a coilover, just a stock format coilover, rather than what everyone calls a coilover.
    • Yes it is. We get stock from Nismo directly. I'm happy to take photos/video of it as proof before I ship it with timestamps or whathaveyou.
