$175 is second hand.. $199 new.
To install the GTR resistor pack you need to cut and solder it in to the loom.
There may be an importer that flogs them off for cheaper.
Edited by Cubes
like anything.. diy.. and save the bucks... or get correct impedence ones and pay somebody else to fit.. if you are on a budget you could also investigate rx7 injectors
most workshops would probably tell you are "wasting your time" by getting them to install such small injectors.. they'd be right, if you pay them to do it. but if you did it yourself, the cost would be minimal.
you will need your ecu remapped to accept them anyhow.. thats a $50 job if u know how to do it yourself.. but all the pros that do it will charge you $200+
if you are lucky you may be able to just SAFC it, but that may be quite problematic.
Either way, its probably close to a $1000 operation..
Now these CA18DET injectors u can get nice and cheaply.. :P
good reply sk  (  /me bookmarks thread for future reference)
if you wanna go sard injectors
SARD High Resistance Fuel Injector 550cc Top Feed (63506)
SARD High Resistance Fuel Injector 800cc Top Feed (63565)
^model number for rb20det.
rb26 injectors are a common upgrade for CA18DET in fact, as they are both the same impedence/type
series 4 rx7 injectors (555cc)  i *think* are a common upgrade for rb20det,  but i'm not 100% on that, so best to check before you go out and buy some.
tell em the price son, the price son!
im not selling them, they are the model numbers.
goto www.garage-13.com and email alex if you want to order them, he'll get you prices. (can also get used rx7 injectors or whatever you want).
  • 5 weeks later...
With regards to the resistor packs.
Head down to your local U-Pull It style wrecker and grab one from a R30 Skyline for next to nothing. The one I picked up cost nothing. :D
Just be sure to cut it off from the loom so you receive the male part of the connector.
Edited by Cubes
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
