$175 is second hand.. $199 new.
To install the GTR resistor pack you need to cut and solder it in to the loom.
There may be an importer that flogs them off for cheaper.
Edited by Cubes
like anything.. diy.. and save the bucks... or get correct impedence ones and pay somebody else to fit.. if you are on a budget you could also investigate rx7 injectors
most workshops would probably tell you are "wasting your time" by getting them to install such small injectors.. they'd be right, if you pay them to do it. but if you did it yourself, the cost would be minimal.
you will need your ecu remapped to accept them anyhow.. thats a $50 job if u know how to do it yourself.. but all the pros that do it will charge you $200+
if you are lucky you may be able to just SAFC it, but that may be quite problematic.
Either way, its probably close to a $1000 operation..
Now these CA18DET injectors u can get nice and cheaply.. :P
good reply sk  (  /me bookmarks thread for future reference)
if you wanna go sard injectors
SARD High Resistance Fuel Injector 550cc Top Feed (63506)
SARD High Resistance Fuel Injector 800cc Top Feed (63565)
^model number for rb20det.
rb26 injectors are a common upgrade for CA18DET in fact, as they are both the same impedence/type
series 4 rx7 injectors (555cc)  i *think* are a common upgrade for rb20det,  but i'm not 100% on that, so best to check before you go out and buy some.
tell em the price son, the price son!
im not selling them, they are the model numbers.
goto www.garage-13.com and email alex if you want to order them, he'll get you prices. (can also get used rx7 injectors or whatever you want).
  • 5 weeks later...
With regards to the resistor packs.
Head down to your local U-Pull It style wrecker and grab one from a R30 Skyline for next to nothing. The one I picked up cost nothing. :D
Just be sure to cut it off from the loom so you receive the male part of the connector.
Edited by Cubes
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
