after fitting my 600x300x75 fmic, and boost controller... my car is hitting approx 15psi or more..
i used to have a 450x300x75 fmic, and no boost controller.. car used to hit 10psi, and the bov made a tad quieter than normal sound..
after fitting the 600x300x75 and boost controller (no adjustment made, tried it without it too), car got up to 0.5 bar as per normal, then it rocketed up to a bar, and the blow off valve makes a very loud noise on throttle release now...
edit: this isnt flat footing it either, this is 3/4 throttle up to about 5000RPM, then changing gears.
only thing i can think of is the hose from my boost controller/bleed valve is a smaller internal size than ther old hose, as it was too short.. is the smaller hose restricting flow to the wastegate, thus pushing boost up?
any ideas would be great, cheers!
Edited by mitchy_
https://www.sau.com.au/forums/topic/85556-over-boosting/
Sorry mate, just re-read your post.
A boost controller will bring boost on much quicker than factory setup or even using a bleed. Add to that a cooler that may have a bit of pressure drop and you will have a world of difference.
Just remeber your stock boost pressure is around 9-10 psi, with a 2 stage boost control, where you get approx 2 psi less until you reach around 5000rpm.
Hoep that helps explain the difference
Edited by Steve
https://www.sau.com.au/forums/topic/85556-over-boosting/#findComment-1549102
the wastegate was plumbed after the intercooler, and before the BOV, and the throttle.
edit: i dont think i have the normal 2 stage boost anymore, ive got a microtech lt12 so it used to hit high boost all the time.
old fmic was a ARC 450x300x60, but it ran the old piping, so maybe the 180 degree bend on the return side caused a bit of pressure drop?
Edited by mitchy_
https://www.sau.com.au/forums/topic/85556-over-boosting/#findComment-1549105
I would think a bend in a pipe wouldnt be causing any type off pressure drop but more likely a restrictive intercooler core....
But previously having an ARC cooler i wouldnt think such a thing, being one off the best coolers available on the market.
Maybe it might be a faulty actuator or a split in the line to it. And you have tried running it without the new boost controller aswell?
thats all i could think off
Cheers
Adam
https://www.sau.com.au/forums/topic/85556-over-boosting/#findComment-1549122
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
