Hi guys.. its that time of month.......
pay day ( yes . us primus yuppies get paid monthly)
and im looking for a stroker kit for the rb25 does any one knoq wany good stroker kits going around ???
i was tempted to go rb30 block but im sticking to my block seems to go preety good as i found out on friday nite so il stick to it..
any info or suggestions would come in handy
thanks :shake: :eek:
https://www.sau.com.au/forums/topic/8575-stroker-kits/
I wouldn't bother to stroke the RB25, it's a great engine but not the best starting point for huge horsepower. Do you have a horsepower figure your aiming for? There are RB30's being built in Perth with RB26 heads which will provide a better base, or the 2.8ltr stroker for the RB26.
It is possible to get alot of power out of the RB25 so why stroke it?
Might be worth looking at what TRY09 did to his engine. Fitting RB26 crank rods and pistons is also possible.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8575-stroker-kits/#findComment-124801
yeah i heard about get the fittings of the rb26
do they fit straight in
can u stroke it out any further from that point or does it stay as a 2.6 then..
dont the rb25 and rb26 have the same block?/ and whats the diffrence between the rb26 heads compare dto rb25??
i was thinking of going the rb30 block but.. then u mite as well call my car a dressed up VL.. and i dont like VL's hahaha
https://www.sau.com.au/forums/topic/8575-stroker-kits/#findComment-124803
The 3litre blocks are nothing like a VL once there completed, with fully forged internals capable of supporting 1000hp. The RB26 head design is quite a bit better, solid lifters, bigger galleries, oil squirters etc.
Yes the RB26 bits fit quite easily, I think Merli has done this so it might be worth asking him.
I think it would be better to keep the engine you have while you start to build or have built for you an RB30. This way your car is still on the road and you can pay for the build-up as you go. The RB30's can also be done with the RB25 head, not as good but can save you some money.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8575-stroker-kits/#findComment-124816
It is possible but not worth the hassle, the RB26 head has a better design in many areas and trying to make the RB25 head the same would probably end up costing more and not being as good.
RB26 head on the 3litre bottom-end is a very strong and reliable build. If your planning on doing the build yourself then cracktest/x-ray all of the parts, you don't want any unreliable parts in a big engine build.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8575-stroker-kits/#findComment-124845
Your lucky to have mechanics in the family. I'd suggest taking your time with the engine build making sure over and over that the clearances are right and everything tightened etc. A guy I know put an engine together himself and it dropped a rod, cause he didn't tighten something.
Good luck with the build, keep us posted.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8575-stroker-kits/#findComment-124890
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
