Hi Guys,
I just bought my first Skyline and now I'm agonisingly waiting for it to arrive. (R33 GTS-T Type M)
Now I know how cars work but I don't really know much more. I'm not a mechanic.
What I'v been thinking lately is
How do I icrease performance without using bolt on mods?
Such as bigger turbo's, increase boost, intercooler etc etc.
Basically, I want to slowly build my car as genuinly fast and the first things I wanna do are make changes to the inside / strength / power of the existing engine and then once the engine is strong enough I will bolt on the bigger turbo's etc etc
The first thing I thinking of is CAMS and possibly head gaskets...that sort of thing.
Can I get a top ten list of non bolt on mods please guys?
I'm also open to people who oppose my point of view and thinking...as I said, I'm not a machanic. (Maybe the engine is strong enough to handle all the bolt on mods straight away)
Cheers,
Sam
As sumo has said, depends on your power target.
the stock rb25 internals have been pushed to 250rwkw time and time again by numberous members of the forumn. If that is your goal, then turbo + support systems are sufficient. A stock motor that is properly tuned will last a long time like this.
On the other hand, if your power goal is 400rwkw, then you'd need to do support systems, turbos + engine work.
K&N Panel filter in the factory airbox.
Full 3" Exhaust (including front/dump/cat pipes)
Apexi PowerFC
You can/should do those to start with and you won't even need to lay a hand on your motor. Expect those to increase power by around 30% to begin with.
Absolutely no point in modifying anything inside your engine if you don't have a larger turbo to bolt on as well (and it sounds like you are far from that) and even with a larger turbo you most likely won't need to modify anything at all inside the engine.
Cheers,
Sam
The engine is strong. Strong enough to go well into the 200's RWKW before you need to do anything other than bolt on.
Personally I couldn't wait and went for the bolt on's first.
I probably will not reach the limit where I do need to crack open the engine.. but who knows. Maybe one day.
El Bee
Apexi PowerFC
Cheers and thanks for all your help guys. First thing on the list...Power FC. ooohohh can't wait!!!!!!!
Now I'm gonna go and put myself in a coma so when I wake up my skyline would have arrived. This wait is killing me :D
  • 3 weeks later...
hmm rb26 heads on rb30 block...then when you feel like upgrading then bolt on the goodies
yeah i agree with Ryosuke Takahashi, if you want to build a tuff engine first than build an RB30DET, then start piling on the bolt ons :D
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
