  • Replies 164
Originally posted by cereal
Make sure you come & say Hi Eric......Even if you are as trashed as you were last time. HAHAHAHA.....You could hardly even stand up!!!
i was fine... wat u talking about.. :lol:
my car runs out of rego today.. trying to get it paid today..
(spent it all in holidays) oh money... why can u never have
enough.... :)
/takes deep breath
Well, I'm coming along to this one, 10pm at cumberland BK, right?
Just one warning, mine's still got the very small, twin, stock exhaust, so I don't think she'll be your type.....
Hope Dino does come along, then there'll be stock exhausts galore:lol:
If anyone wants a ride over, I'll be heading across from Abbotsford (nr city).
Originally posted by Duncan
/takes deep breath
twin pipes?
double penet****** :eek: :lol:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
