  • Replies 164
My god what a turnout. Easily the biggest we have had. I arrived at 9:30pm thinking i was late and was getting ready to leave when 2 or 3 other cars showed up. 20mins later the -entire- carpark was full.
Some nice cars and cool people.
3 virgin
someones gtir
photo is a bit dark so i'll give commentary.
dave gets to rocks
loz gets a hard on (he insists it was the virgin exhaust and not dave)
loz makes his way to the tender exhaust smoothtalking it so as not to scare it
gets on one knee...
...and starts spanking it!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
