Sup people,
My Skyline Series II
Just fitted my Hrbrid cooler onto my car the boys from QSR are great thanks Mohammad :lol:, performance wise you can't really tell any difference but at least I know on a hot day my car will still be running at full boost 12psi, I have completed my breathing upgrades on my car my next step is manifold and modify my internals along with a new ECU to handle the fuel ratio etc. stock ECU just doesn't cut it :lol:
Front bar isn't on as yet, cause I need a Front bar reinforcer if anyone has one for a series II please pm me
Comments well.
https://www.sau.com.au/forums/topic/86403-hybrid-front-mount-intercooler/
Hi R33Zilla
just a couple of questions on the intercooler that you have installed. is this custom piping or is it a kit? if it's a kit, is it the Hybrid GT spec ones?
also, is the trimming of fan blade and removal of A/C fan (the thermo fan in front of the radiator) required?
and is the piping aluminium?
i want to get one of these kits too but i don't really want to cut the engine fan blade or remove the a/c fan, especially when summer's coming up soon
cheers
Hi R33Zilla
cheers
To answer you question NO nothing has to be removed like engine fan blade or removing the a/c fan and its the Hybrid GT spec cooler full kit + piping for rb25det you can find this coolers at a great price from my friend Ray [FLYN] from ns.com say I reffered you
http://www.nissansilvia.com/forums/index.php?showtopic=99722
the only thing you have to do is drill a 3" diameter hole on the chassis so you can feed the pipe through easy stuff
i don't know yet, i might just get it through your mate in the end, i've just checked his thread and the pricing does look competitive, especially for a quality tube and fin cooler.
but before that there's a few other things i'm doing to the car now so i won't do it for another month or so.
btw, i've seen one of those gt spec kits for an s15
i was surprised how much it's improved over the old hybrids. the construction definitely looks more solid and well done
they're also lighter too
workmanship on these coolers are excellent, even if you compare these to the big dollar jap coolers
Edited by tkch55
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
