I was wanting to do something different with my R33 Dash Piece that goes from the gear stick, up over the climate control and stereo deck, and around over the top or the steering wheel to the other side.
I want to make it a new colour, has anyone else done this before? Can someone guide me to some pics perhaps and does anyone have suggestions of what colour I should go for and how to do it.
I was thinking a nice random bright orange or a blue, the car is gun metal grey and the interior is all dark in colour. I was thinking rubbing down the plastic and then going over it with some plastic primer and then what paint do I need to use?
All help/suggestions/advice and comments are appreciated.
Thanks,
[ SKYRYAN ]
https://www.sau.com.au/forums/topic/86527-custom-dash-colour/
simple go to your local paint place and ask them what they recomend
i just lightly sanded to get rid of original flakey coating plastic primed then top coated you can then clear but i was woried bout reflection/ glare
my dash surround is in a light grey with the feature pieces ( inst cluster speaker grills etc) round the cab in a light metallic blue
all done at home in the shed with spraypacs
only problem with making a new colour is u gotta remember the mixture levels and stuff.. i did a mix of red a while ago and the guy that did it for me just went "ohhhh lil of this that and the other" and then we found it hard to match :P
just make sure u make enough of the paint if u need to do other parts of the interior or what ever :)
im takin mine to an airbrush artist, gettin him to throw out some ideas. , or some grapha mates might have a go at gettin somethin goin, thats my 2 cent's, its white atm but man it sucks when ya on ya 4th coat or white then bam!! ya get one tiny bit that didnt take, gotta peel it all of again. ill try find some pics
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
