post-15860-1126004225.jpgpost-15860-1126004327.jpgpost-15860-1126004424.jpgpost-15860-1126004491.jpg
Hi guys,
I have a friend that owns a stainless steel business who has the tools to make and supply me with hand-made 100% stainless steel gear knobs at a reasonably cheap price.
Chrome, black chrome, and custom engravings may become available options later on.
I would like to get some feedback and see whether people would actually spend a bit more money on a decent gear knob or would rather just buy a cheap one with some brand name that was thought up in China, because any of the good brand gear is too expensive.
Most of the cheaper GK's that you might pick up from say Autobarn or Repco are usually a metal such as aluminum, which is very light-weight and fades/scratches quickly. This is what happened to mine and was the reason for making my new GK.
Not only does my product look slick and simple, which is what most people want these days, but it gives the driver a more solid feeling gear change.
My gear knob weighs 202g as opposed to the old one which weighed only 80g yet has exactly the same dimensions. That is 2 and a half times heavier. I suppose that like jewelry, a good factor in determining the quality is the weight/solidity of the product.
So far I have only seen the TRUST G-REX stainless steel gear knobs and some NISMO variants that are actually stainless steel, but unfortunately they cost upward of $100 each.
I have noticed that people on SAU often need a GK and are willing to pay say $40. Why not pay a bit more and get good quality, knowing it will last longer as it is quality steel?!
Until I get a response but I cannot say exactly how much they will cost, but it will be more or less around the $60 mark. Don’t forget the cost of stainless steel is much higher than that of the cheaper metals.
So far I know that they only screw onto r33’s. I am soon to try r32’s and 34’s but am certain it will be the same fit for most gear sticks.
If I could get at least 10 buyers to start, I could have them available in a matter of days. If many people are interested, then I will keep a constant supply coming in.
Cheers
-Serge
Edited by SRG33
Guest
    • So I actually had the cover off my car today, here is a (bad) pic of the setup. I have an oil cooler thermostat block, the temp sender is straight in there. The pressure sender has a short AN line to a T piece which is mounted (hopefully cable tied counts as mounted....) on the chassis. BTW every fitting you could ever imagine exists....just depends what they cost and how many you need. Raceworx AN adapters are here: https://raceworks.com.au/fittings/adapters/, I think you said you need BSPT to AN (https://raceworks.com.au/fittings/adapters/bsp/tapered/an-to-bspt-adapters/) and AN to NPT (https://raceworks.com.au/fittings/adapters/npt/) BTW, braided line is super simple to make. It looks intimidating, is not.
    • Perfect day for a pie, really needs a soft top in this weather though
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
