hey.. i'm new
Guest J.Spec00
Originally posted by INASNT
is that a mates car u are gonna buy?
u recon it will still be around when u get on your p's?
its not a mates car..
its from a private importer..
obviously when i get around to getting a car... it wont be around.. but i hope to get something similar...
so ambz... ur GO SPEED RACER is a calibra... *cough* *cough*
lol.. only J/K
https://www.sau.com.au/forums/topic/8678-hey-im-new/#findComment-127596
since the clothes u supplied me from your private collection had pee stained undies and all this hair on the bra's!!!
jesus christ? what the hell is going on????
1.) why were you looking to wear girls clothes?, ive heard rumours going around about this kinda thing, now they are confirmed
2.) why were they pee stained and hairy?
when u were cryiong in the test lab
https://www.sau.com.au/forums/topic/8678-hey-im-new/#findComment-127635
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
