hi, i got my r33 on 10 psi boost, just woundering if it relly make a diff if the spark gap is 1.1 or 8mm. can any1 please guide me how to remove cocker cover, help would b get. thanks  :D
I have gapped mine down to .8 mm because it was mis-firing. Still havng the same problem but. If it is not causing you any troubles, I say leave them alone..
And you want to to remove the 8 or so allan key bolts from the plastic cover on the rocker to get to the plugs etc.
https://www.sau.com.au/forums/topic/86862-rocker-cover/#findComment-1568750
    • ok so if i wanted to go 18's i would go for 8's  in front 30+ or 32+ off set at front and the back 9 would be ok? what offset should i aim for.. then can i do some  hunting for wheel rim choices..
