I have 2 FSM's one for the R32 and one for the R33. I am hoping there are different Service manuals for the car because none of the ones I havehas a wiring diagram that identifies what each connector IS on the harness.
Here are some diagrams for my 240sx. These are the kind that I need.
Does anyone know where I might be able to get a diagram like this for the R32 RB26dett?
s13_el_3.pdf
It seems that I don't get any responses without these pics:) LOL seriously though,
I really need diagrams to help sort through this mess. We're making progress, but a connector identification diagram would be super great!
Why do you need one?
I'm wiring the rb26 into my S13.
We were having a hard time reading the main wiring diagram. Having one that was broken down into systems and locations like the diagrams I have for the S13 would have made understanding the R32 loom much, much easier.
We're making progress however and should have this harness disected in a few hours. But if anyone has one, it would still be helpful.
imo it's pretty useless. Look at pages 790 and 791 in the R32 FSM. There you have wire colors and harnesses. That combined with the s13 fsm should be all you need. For the lower harness you should be using the s13 harness adapted to the knock sensors, alternator, etc..
GOOD INSIGHT!!! Actually it's for the 180sx. You'll notice that there are connectors similar to the rb coilpacks indicating a CA18 motor. The diagrams are nearly useless to use, but it was a great representation of the type of diagrams we were looking for.
We're nearly done however. I LOVE NISSAN!!!! Once you understand what you're looking for it's all so very very simple LOL
whew, I'm excited, I might even get this thing started TOMORROW!!
Thanks for the thoughts JIM, it's hard to get responses to your questions on this site sometimes.
Edited by RB240Dav
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
