*price alteration*
Item: 1998 R33 GTSt
Item Condition: Excellent
Rebuilt Engine by Amberley Autos (around 30,000km old, Receipts, Service Records and Dyno charts)
Custom forged pistons
Shot peened and lengthened conrods
Crack tested, strengthened and linished crank
1.2mm metal headgasket
550cc SARD injectors
Bosch internal fuel pump
DNA Motor sport front mount intercooler
Trust air filter
K5-660PS Blitz turbo
Custom stainless steel exhaust manifold
53mm Blitz external waste gate
Custom stainless steel turbine outlet into a highflowed catconverter into a 89mm Fujitsubo Legalis SuperR exhaust
PowerFC w/handcontroler
Defi BF Oil temp and Boost gauges
Some minor stereo improvements, nothing fancy
GTR copy front bar and skirts
HKS HypermaxII adjustable coilovers
Whiteline Rear and Front antiswaybar
Whiteline Front adjustable towerbrace
Factory rear adjustable towerbrace
New Daikin super heavy full faced button clutch
KAAZ 2way SuperLSD
Tomei HICAS lock
18x8 Enkei Bortex wheels
Mongoose Alarm
The Blitz K5 turbo kit has been on the car only since the 2nd of September 2005
Completely reliable, starts everytime and runs perfectly.
Maintained by Amberley Autos, always garaged.
Rego till November 2006
Contact Details: 0414 805 480 James
Reason for Selling: Need a normal car, spent too much on this one
Price: $27,000 Negotiable
Contact Details: 0414 805 480 James ([email protected])
If you want it to see more power, than a set of cams, bigger injectors and an extra fuel pump will see you happy.
This is a complete package car. You won’t need to do much more as you’ll be happy with the way it is.
ps: dont mind the drift nationals sticker on the windscreen...its only there to promo Fulllock. I cant do that crab crawling sh|t and i dont act like i do with the car either.
SOLD
Edited by whistla
https://www.sau.com.au/forums/topic/87034-1998-s2-r33-gtst-forsale/
Ive seen the car before and Its gotta be one of the hottest R33 GTS-Ts ive seen around! The mod list looks insane as well, good value for 30K!
Good luck with the sale.
Free BUMP for my brother whistlazzz
I have seen this car come from a mild street car to a full blown weapon.
Its the perfect car to buy because there is no more to spend on it - its complete !
Tuned professionally giving a nice linear torque curve makes the seemingly large turbo spool as if it was no bigger than a t3/t4. The useable power is fcking awesome.
I'd Buy it, but i am afraid of what i might do to it =\
  • 3 weeks later...
How many rwkw does it have?
Sorry for the delay.
Its currently got 276rwKw on a very sedate tune/setting. It is more than capable of doing alot more.
Im just a girl as some would say, and didnt want much more for street use.
the K5 is a 660PS rated turbo.
Same turbo on two other RB25DETs has seen it produce +400rwKw, but ofcourse with the supporting modifications.
eg: alot bigger injectors/pumps and cams
Edited by whistla
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
