Ok before anyone asks, no I haven't banged my engine! (touch wood!) I have just been following the arias piston thread and thought that these seem to get the nod on some occations...
so I gather they are made in the USA, what are the prices here like?
87mm seems the go also what about 9 : 1 or 8.5 : 1 ?
I have found some in the states for $970 aussie... complete with rings etc....
ideas :P
Contact Markr34gtr is the man to talk to for CP pistons (very nice product) i used a set from mark on a r34 gtr vspec making 500rwhp plus happily. They run a 0.0035 clearance which is pretty good for forged pistons.
pete
Williams, that's pretty cheap if they are complete with rings.
One thing you need to be careful of with CP pistons, is that you get different rings depending on where you buy the pistons from. CP don't make their own rings.
I know if you order from CP direct, you get a japanese made ring. If you buy a set here, I'm pretty sure you get a US made hastings ring.
Also, the 87mm pistons you buy here are not an off the shelf CP piston, they are a custom piston and use a different ring width to the 86.5mm pistons (and the US 87mm pistons)
By the way Tomei pistons run 0.002" to 0.00225" clearance.
ok the reason I ask is I have found a place in the USA that does RB26 CP pistons... 86.5 and 87mm same as what cousin blitz has got....
I found the price to be rather reasonable, and that is with American rings matched to the pistons....
oh and that price would be me picking them up in LA :huh: but that isnt an issue....
but I am (touch wood a lot!!) not looking at doing this for a while, just curious as to the price diff locally...
ok the second part of my question has been skipped, comp ratio??
pluses and minuses for 8.5 or 9
cheers!
oh and that price would be me picking them up in LA :( but that isnt an issue....
cheers!
Hey Ben, I think you'll find the American 87mm pistons will be a different piston to Nicks ones. The Aussie distributor custom orders the 87mm pistons with thinner rings.
G'day Mik,
I can't say either way regarding the thinner rings, just that the CP pistons are for the RB26 and come in the 4 different options of size and comp....
I have emailed them regarding the rings spec...
Rob82...
no my engine is still in 1 piece... I was just asking out of curiosity....
I should think my engine should be going for sometime yet!!!!
here is the link to the site....
http://www.bnecustoms.com/store/home.php?cat=453
and CP
http://www.cppistons.com/sCompactNEW.htm
ben,
why aren't u speaking to jim @ dart? he recommends arias because of the ring quality (eqiuvalent of nismo rings)
at the end of the day its like asking the question of holden & ford?
it is personal opinion & they both have 4 wheels...
marko
hey mate :(
yeah I had the discussion about either of them a while back, I was just curious about the CP as I don't know much about them, and I know the arias are a good thing....
so how many km to go till u get some real boost? :)
hey mate ;)
so how many km to go till u get some real boost? ;)
Ben,
CRD recommends 1500km whereas Dart recommends 1000km
i may do 1250km :)
I hear you may be moving to Adelaide for good!?
Marko
yep! leaving old Sydney town...
well never say never.... but Adelaide is home, and plenty of GT-R friendly roads over there...
I'll just commute for work ;)
you will need some semi's for that car of yours now surely!!!
ok this back in from the piston supplier....
"The rings are produced by CP Pistons. They are made of tool steel. Tool steel
is harder and stronger than the chromoly ones that everyone else sells. Plus
the tool steel rings seat a lot faster than the chromoly ones.
You also get Chromoly 5100 series pins, and wire lock retainers."
so they are made my CP?
That is very odd. I was told CP don't make rings. The guys at CP in the states told me that they supply a Jap made ring.
The aussie dist supplies either total seal or hastings (US made rings)
Another weird thing...I always thought chromoly (ie chrome molybdeum (spelling??)) WAS tool steel!! ;)
But in any case, if I were to use CP rings, I would get them custom made to accept OEM rings and OEM tru arc locks.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
