New Oil and Filter - Check
New Fuel Filter - Check
Bottle Warmer Wired - Check
ET Street Radials - Check
VP103 and 2 Full Bottles - Check :wub:
Spares, Tools, Awning, Food, DRINK, Mechanice - Check
Sleeping bags, air matresses.....errr......
BRING ON QLD!!!
Adrian
https://www.sau.com.au/forums/topic/87308-jamboree/#findComment-1585674
Pretty woefull really - the driving rain filled up the first two spark plug holes and resulted in unintentional water injection - boost wasn't staying controlled so we backed off the gas and ran again. was still breaking up so we pulled the plugs and found the water :)
new plugs and 75hp gas with heaps less fuel was better and cleaner but still way too fat (11.3:1 AFR's and 111mph) so we bumped the gas back up to 100hp and kept the fuel as it was and saw 12.0:1 AFR's across the whole of 3rd and 4th gear.
As this was our 4th run, the time didn't count towards qualifying - would of easily made the quick 16 if it did :O:):(
Either way we still had a ball of a weekend and Stuart from Bezerkly was as good as ever - (especially when I was breaking down and being a cranky man).
Big effort to TWOOGLE too!
https://www.sau.com.au/forums/topic/87308-jamboree/#findComment-1594241
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
