Item: R31 GTSX (Coupe)Red Top RB20DET, Hicas, 4 wheel steer, AVCR, SAFC2, FMIC, 3 inch exhaust off turbo, 17" RS5 rims, momo steering wheel, autometer boost guage,quality cannon, pioneer 6x9, 10 stacker,full skyline matts(front and rear) turbosmart type 2 BOV, AAH31 number plates. 152 000k's
Item Condition: Top condition. One small dent in one door. Paint is e good, no rust, no fading! Interior is in great condition but for a few 'JDM' cigarette burns. Dash and door trims are immaculate, carpet is spot on, no rips or tears in the seats.
Engine always driven with respect. Oil always changed @ 5000kms. I love this car, it is my baby so it never got thrashed. IT IS NOT A THRASH BOX! Very smooth to drive. Was running 12psi when i purchased the car, since installing the AVCR and SAFC2 i have only run 6 psi.
Reason for Selling: Saving for a house and as we all know saving and cars don't mix
Price and Payment Conditions: $10 000 ono.
Extra Info: If you aren't interested in this car don't post here
Contact Details: Contact Grae on 0422 933 560 or [email protected]
Edited by locograe
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
