12 volt dc 10amp (normal dash lights) dropped to 1.5 volts (LED) 1mA something like that so you will need to find out the total power draw should be 10 amps but that will be total in dash draw so you will have to match that to stop the leds blowing up due to high voltage and high amp's.
HOpe my rough example kind of helps
ps board at work so thats the reason being the diagrams
both are ideas of wiring the new leds
  • Replies 78
cookie: From what I can see, I just need to play with or replace one of the two to get the other half of the panel going.
Sumo: yep! I took pics when I was doing it... will attach thanks!
Pic 1: The AC unit in an R33. the recycled air and demister have their own individual green bulb/LED for the little rectangle which lights up green when pressed.
Pic 2: The rear of the unit. There is one bulb here, and one on the other side. There is a groove on the rear of the bulb which accommodates a flat-head screwdriver just nicely. Unscrew, flip unit, and out it comes. Check your contacts and bend the metal of the bulb out a bit if it looks like it has "unsprung" itself over time. This has fixed one of the two for me purely by accident.
Pic 3: The bulb and rubber cap. If that doesn't insulate heat, I don't know what does! The buttons are not super-bright to begin with... I may try peeling the rubber off the working one to see how bright it will go. Sure it'll be white instead of a light blue, but who cares? I can see my buttons! ($10 if you find a 4-leaf clover)
Well stuff *me*! =-o
The globes DO come out eh? Shouldn't be too hard to source the right replacement globes for the holders then!
If I find the time, i'll pull them out this week and also let you know how it goes, Steve.
I had to change mine a few years ago. Back then I bought them from either Jaycar or Dick Smiths. They are called 'grain of wheat bulbs'. Silly name, but thats what they're called. Cost me a few dollars each.
Edited by SLY33
Yesterday i tried to follow the instructions to do the swap from the silvia link - only had time to put two lights in - and they turned out way to dark, i will try again with some different bits and let you know how it goes
what mcd leds did you use the 1000 ones maybe a higher rating im getting my leds tomorow n1
yeah i bought 1000mcd leds - well a mate of mine did for me - he's a Qantas technician and loves fiddling with that stuff.
He suggested changing the resistors first then if that doesnt work to go for the 3000mcd ones cause i dont want them to be to be too bright as im driving at night and he thinks 3000mcd leds will blend in with my stereo headunit - theres better things to look at, like the boost gauge (and the road from time to time :P )
I should have a result by Friday for everyone on this topic
hey, im 3am on ns.com and I wrote that article :(
when I wrote it I just bought the cheapest LEDs I could find, hence not the brightest ones. but its all down to personal prefrence, I think that if its too bright it may be a distraction.
anyways glad to see my article is getting around. :(
Hey - good article - with the polarity it was different on my R32 (which i was sort of expecting) (some are left facing and others right facing)
Id recommend 1000mcd bulbs aswel, any brighter and like you said, it can be distracting. Plus - how often do you fiddle with the ac? personally i just set it and leave it so i find it irritating being in your face all the time, the stereo does a good job of that anyway!!!
Again - good article dude!! - ill post night shot pics asap
there a standard dick smith job replacement, blue leds look good on the recycle and demist buttons cos ive done that already, but dont use leds for the main lighting, it wont light up properly because blue leds have a very narrow lighting angle
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
