Hey All,
I'm going to buy and install a greddy turbo timer into my r32 gtst, apparantly they can do vehicle road speed, 1/4 mile time 0-100 etc and all that works fine in my friends R33 GTST, but R33's have electric speedo and therefore the ecu knows road speed and can calculate. R32's have mechanical speedo and i'm not even sure that the ecu knows vehicle road speed and therefore the functions won't work. The car is a Type M but I'm not sure if it has ABS ( the car is still on the boat) so the ecu might know speed from that. I just can't get my head around it.
Also how do I 'bump up' posts of mine in the 'for sale' section. Any help = greatly appreciated.
https://www.sau.com.au/forums/topic/87626-turbo-timer/
to bump u just post in it, and it goes back to the top of that forum, but i dont think its allowed....not too often at least
not sure about the turbo timer questions, but im always interested in stuff that ill need to know when i get my 33, so yeah
https://www.sau.com.au/forums/topic/87626-turbo-timer/#findComment-1581648
there is a wire that goes to the computer.... wire 53 i think? this is the speed sensor wire...
ive got a greddy turbo timer and a R32 so i know it works.... just splice the wire and join it to the turbo timer wire and your TT will recognise the speed once you synchronise it :D
Ed
https://www.sau.com.au/forums/topic/87626-turbo-timer/#findComment-1581690
Ed
are you guys talking about just what speed your doing, but reading it from the ECU, and not the dash speedo which can obviously be out? or am i way off
https://www.sau.com.au/forums/topic/87626-turbo-timer/#findComment-1581735
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
