just thought i'd help out ppl that r about to buy skylines..
if anyone wants to make this sticky.. go ahead
The year of manufacture can be found by looking at the front seatbelts, near the floor mounting point. There is a fabric tag with the seatbelt specifications and the year of manufacture sewn onto the webbing.
Inspect the welded seams in the front door sills just below the plastic kick plate. This is where I have seen rust start to form on Skylines, especially the R32. The R33 has an identical seam, so these will also show in years to come.
Remove the rubber around the boot rim – this is a prime rust spot in any car. While you are in there, look in the side panels and make sure they are not full of water.
Feel inside the panels in the boot where the jack is – debris found here will tell a story.
Watch for glass (broken rear window or tail lights at some point)
Inside the engine bay, look for crayon or chalk marks on components – this may indicate they have been replaced with second-hand parts.
Crawl under the car and inspect behind the front and rear bumpers for signs of collusion damage.
If you are keen, use a set of vernier callipers to measure the panel gaps especially on the doors.
Mechanical – a noisy ceramic turbo isn't a good sign – see if it has been replaced with a conventional steel type.
With the front wheels off the ground, check the play in the top end – any more than 5mm and there could be expensive repairs needed.
Watch the oil pressure when the car is hot – Keep in mind the oil pressure sender is prone to failure. These are the factory specifications for oil pressure on the RB20DET:
1kg/cm 2 @ 600 rpm
3kg/cm 2 @ 2000 rpm
4kg/cm 2 @ 6000 rpm
After Purchase
As you may not know the history of the car, it is best to start with a full service.
Air filter – replace.
Fuel filter – replace.
Run a bottle of injector cleaner through the system with the next tank of petrol.
Oil filter – replace, and change the oil. If there is a sludge problem do a hot oil change and repeat within 1,000 km. Don't use an engine flush treatment.
Automatic transmission – have the oil changed. The transmission cooler should also be flushed.
Spark plugs – replace. Make sure they are replaced with the platinum resister type.
Timing belt – inspect and replace. Nissan specify a 100,000 km life for these. Be safe and prevent the rain of valves.
Radiator – add plenty of anti-freeze. Without the protection of anti-freeze (corrosion inhibitor) there are parts that will corrode and eventually cause you grief. Check the condition of all the hoses while you are at it.
Battery – monitor and replace if needed. Japanese car batteries are smaller than the regular sized car battery, and it may be the factory fitted battery (over five or six years old)
ECU – reset it. Make it learn our driving conditions.
https://www.sau.com.au/forums/topic/8772-skyline-buyers-guide/
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
