  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I couldn't warrant a new thread so I thought I would just post here instead..... I'm excited as I have just ordered my HKS cooler and Apexi AVC-R from Nengun... :)
Hehe in a few weeks I should be moving along very nicely :burnout: ... Can't wait for the next croose so I can meet up and see some of these cars you are talking about!!! :uh-huh:
Brett
Skyzerr, What suspension was it, Koni adjustables?
MrGTST, Nice way to spend a few K, should be worth it for the difference in performance. Hope it all goes smoothly. The next cruise is this Sunday, and then one the following week. Hope to see you there.
See'ya:burnout:
I believe the 255x40x17 refers to:
255 - Width in "mm" of the tyre
40 - The profile of the tyre. I.E the smaller the number the thinner the tire is.. I hope that makes sense
17 - The size of the rim in inchs
I hope that makes sense :(
Skyzerr, sorry about that dude, I was trying to reverse park the car, and pressed a little too hand on the phone. Couldn't ring you back cause I have no money left on the phone. Sorry.
rev, those widths seem a bit optimistic, 9" rims need at least 255's to fit, preferable 265's.
Macka brought the baby oil and I brought the whip, was a good bonding session.:lol:
See'ya:burnout:
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
