  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
it justifies itself, if u pay around $25 a month for dialup, then you gotta look at phone costs, around $35-40 a month (second line) thats $60-65 for dialup, you pay that for ADSL, then u can get rid of your second line, just the initial cost that is a pain ie: modem, setup costs, etc etc. ;)
