for ****s sakes
i missed out on another good nights whore
ahhhhhhhhhh shit hey
i see no talk of animals tonight
good boyz!
or is that coz nizmo and ken weren't involved?
speaking of ken
haven't seen him round the whoretown for while!
adrian :P
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Psiker
i could say the same to u ken "posing"
nah i odnt check that
im too tired so i just press submit. and its hard keeping up with pwpttf
Psiker
That was deliberate to see if you were watching .:D
Cheers
Ken
Hey Paul.... I know you do "IT" .... but more specifically what part of IT??? I too work in IT as do alot of people that seem to drive skylikes!!!! and I find it curious to find out what areas people find there way into... Is it a desktop support type of position? ( Assuming becuase its only a few days a week )
    • If by axles you mean driveshafts, they're supposed to have play in them. They are not hard to recondition, it's just pulling apart the cv's, cleaning them and regreasing, fit new boots. I've only rebuilt one set and there was fk-all wear in them, still running just fine 8 years later.
    • Note, the aluminium bit that screws in the end that you have to remove to dismantle the rack is single use as it's punch-marked, it will strip when you unscrew it, and then you have to flatten the notch in the steel rack body, screw in a new aluminium end when rebuilding, then punch-mark it again once assembled. it is also 'somewhat tricky' to refit the rack>steering wheel linkage gear as it needs to be set to the right preloads etc. A rebuild is probably something that's better just given to a steering shop for a couple of hundred, unless you're mad-keen to do it yourself.
    • Do you have the workshop Manuel? Sorry that's a Spanish waiter...I mean, manual? Some relevant pages>
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
