  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Paul... if you could find out, that would be great.
Psiker, nah, I've had a problem holding 17 psi and just lately there was a little bit of smoke after a hard run at idle.. so.. i stripped her down and took the turb into Per4manz, there was shit loads of shaft movement. practicly NO thrust washer left, and the whole thing is rooted. GGGRRRRR
it was only built 5 months ago. thats what i get for staying with the poxy stock afm.
