my Zx was fast hehe it beat a skyline haha pity i wasnt there to witness i took the 200sx home that night - cant remember why i think my car had just come back from getting fixed and the other half wanted to test it hmmm only time i let him drive my car. But it had a crazy backend wouldve made a good drift car - should clean it up and bring it one day - friggin loud exhaust too!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah its cool haha it's better in the less extreme though - got a mate that spikes his hair but defiantely no where near that. ?Wont let me touch it but will let me cut it - go figure - if i was him i wouldnt let me near his head with a pair of scissors.
http://www.carsales.com.au/pls/carsales/!pv_content.pv_vehicle_list?search_type=7&search_category=1&search_category_chk=2&make_id=5&selected_make_id=54&make_name=&model_id=155&selected_model_id=4&price_min=&price_max=10000&keyword=&search_postcode=&search_distance=50&location_id=&selected_location_id=&state_id=&region_id=
a looong website address but that'll get u there - last one on first page - black one of coarse :P
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
