  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i went for a bit of a cruise - gotta do something with that suspension i think its gotten worse eeek its awful i'll see how the funds are looking this week then do something with it.
Niz all dressed up - no where to go :D Bit lost today dont quite no what to do with myself.
oooh ive got air con compressors on my bedroom floor - my old one and my new one - not sure what to do with the old one - chuck it out i guess its completely buggered useless to anyone. Oh and because ive got two sets of gen floor mats ive got one set on my bedroom floor - my cat loves to lay on them - and my gtr poster i havent put up yet.
Hhaha did i mention i was untidy hehe
I try to choose clothes that dont need ironing and the ones that do i do 5 mins before i rush out the door - something else thats against my religon - thank god i dont have to do andys work shirts any more - its usually something out of that new king gee (i think it is) ad where he's got an iron print on his backside hehe
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
