Originally posted by Micko
Still can't figure out why the reference is out for base timing, but got the CAS at about midpoint which should ba around 20 degrees - no pinging as best we can tell.
Hopefully put the car on a dyno tomorrow to check a couple of things are normal & then if all is good I should be able to put the problems behind me
*crosses fingers*
yea , lets hope so .
Have you had the CAS in the same place before ?
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Makes me wonder whether there ever was a problem with the knock sensors - who knows as long as it stays away, I don't really care.
Must say I have learnt a lot about the car throughout this process, so that definately makes things worth while (kind of!).
Well there must have been a prob somewhere or it wouldn't have kept showing a code
Cheers
ken
Nizmo - I dont know either, I'm just repeating what other people have told me:)
Shaddup and listen.
Geez , a women comes on and Micko goes off the topic.
Remember , your married:D
Cheers
Ken
i tell ya theres some real crap on TV!! Mum hijacked the computer there wasnt much happening so i told her she was welcome too.
Bloody family - having to share - glad im an only child - with siblings it would be worse!!
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
