  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
no havent been to steves i have heaps of mates that go there and usually on a thurs morning ive got a couple of messages on my phone - u at steves? u at steves? been meaning to go there!!
Micko - what training at Mc's are we going to do because there was talk of having some license blahblahblah etc etc etc - what training are they doing and do we get to use our own vehicles - because im more interested in learning how to thrash my own car - ive thrashed too many toyotas celicas and bathtubs (mr2's) already when i worked at toyota and neither impressed - more would like advance driver training for the car i already drive. also price?
Yeah well i may go one day 33Spec2!
weekdays i dont normally go out on weekdays - to tell ya the truth i find northbridge bad enough on weekends - the guys are like pirhanas - and i dont mean to sound up myself but i get sick of lame guys approaching me all the time in the hope to get laid. Plus theres a guy that usually goes to Steve on wednesdays and id rather not bump into him.
$185 dollars is an awful lot of money to get someone to teach me how to drive my own car - i can do that thru my own mistakes. When is it - if its like a month or so away count me in - i can afford it by that time. Who else is going? the fact i get taught in my own car is a major plus - just need a date to make my discision and any requirements like helmets etc. Also the promise that my baby wont get marked by any of those nasty witches hats.
bathtub is as slow as Joe - in fact why people want to buy new MR2's is way over my head - slow as mate - nothing special at all - hot as all hell in summer - in fact i used to prefer taking a plain jane corolla anywhere than an MR2 - all of us did it used to be a fight of who we could offload the MR2 too!!
Trust me i bump into so many ppl id rather not there but really who cares im always wit my friends so i make an excuse not 2 talk 2 em like when i went this week some ppl were shouting out my name and i was like who the hell are they are they talking to me? so i went up 2 em and they were like do u remember us? Oh sh*t i was thinking i hav no clue so i just said Fark no and theywere ppl i went 2 primary school wit! how embarrassing i hate running into ppl!
33Spec2 - yeah bumping into people i would rahter not see is one thing - i can handle that. But this guy - its a long drawn out story that started when i was 14 and to ths day he's still messing with my heart - i just would rather not. Trust me im not sentimental over anyone - except this guy - it just farks with my head too much.
Ok 29th should be able to afford it by then suspension will be done, car tuned its just a matter of money left over after all that - but at the moment its pretty positive - so book it - if at the last minute i cant come im sure i'll get someone to fill my place.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
