  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Silent Ken? Don't know, might be in trouble from the Mrs, too many phonecall's from pesky GTR owners:p
See'ya:burnout:
I reckon you're right there pal - sometimes I feel like he wants to say f*&k off, work it out for yourself - but he's been very patient with me.
I prolly ask too many questions, bit i reckon I only ask em once:)
ok thats fine as long as bloody witches hats dont hurt car im in (i havent run into them before haha so i wouldnt know!!) Yeah guess ive got to give u guys something to laugh at - plus i wouldnt ming doing some crazy shit in the car in a controlled environment - not like yesterday me taking car for a bit of thrash - guy deciding to get on my side of road then seeing how fast i was going quickly reconsidering the previous thought hhahah.
So im in agh even if its a ridiculous sum of money!!
