  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Ken,
I know alot of people who want to kick his ass, but I don't have the budget to do that. I just want to take my fully modded street car and race it.
See'ya:burnout:
well forget getting more power.
Go for the biggest badass son of a bitch they stop , mother fu**er brakes on it and strip the car.
ANY road car using road type brake rotors and calipers will not last 6 hard laps around there.
If it does , yo ain't trying hard enough boy !
Cheers
Ken
Ken,
If you were her father, then I bet she thanks god she looks like her mother:p
See'ya:burnout:
well thank god I'm not her Father cos it would be incestous thoughts not just dirty old man thoughts.
Hehehe
Cheers
Ken
ps Just kidding loz , really . Would treat you like a daughter, honest.:P
I have the option of buying R32 GTR brakes, don't know if they are worth it.
See'ya:burnout:
Ahh you have 4 spot 296x28 mm rotors on the front of yours.
R32 gtr have 4 spot 296 x30 mm rotors on the front.
The gain is ?.......
Cheers
Ken
I have seen a set of 8pot Brembo brakes, I think they would do the trick, tied with some 360mm disks:p
See'ya:burnout:
NOW ya talking.
Trouble is can only go up 1 inch on std size wheel so 360mm are a bit tight.
But you are getting the idea. must get the ones with no dust seals or will set fire to them ( I did )
Cheers
Ken
Cheers
Ken
2mm paul only wishes he could get an increase like that where he needs it.
:P hehehe
They are cross-drilled? So not much point. I'll have to buy some decent 6pot AP's, don't want to sell me yours?
See'ya:burnout:
crossdrilled for racing is crap.
Stress heat cracks start from the holes and run to the outside very quickly.
In fact I don't know why they cross drill discs?
Cheers
Ken
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
