  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Ken,
I know alot of people who want to kick his ass, but I don't have the budget to do that. I just want to take my fully modded street car and race it.
See'ya:burnout:
well forget getting more power.
Go for the biggest badass son of a bitch they stop , mother fu**er brakes on it and strip the car.
ANY road car using road type brake rotors and calipers will not last 6 hard laps around there.
If it does , yo ain't trying hard enough boy !
Cheers
Ken
Ken,
If you were her father, then I bet she thanks god she looks like her mother:p
See'ya:burnout:
well thank god I'm not her Father cos it would be incestous thoughts not just dirty old man thoughts.
Hehehe
Cheers
Ken
ps Just kidding loz , really . Would treat you like a daughter, honest.:P
I have the option of buying R32 GTR brakes, don't know if they are worth it.
See'ya:burnout:
Ahh you have 4 spot 296x28 mm rotors on the front of yours.
R32 gtr have 4 spot 296 x30 mm rotors on the front.
The gain is ?.......
Cheers
Ken
I have seen a set of 8pot Brembo brakes, I think they would do the trick, tied with some 360mm disks:p
See'ya:burnout:
NOW ya talking.
Trouble is can only go up 1 inch on std size wheel so 360mm are a bit tight.
But you are getting the idea. must get the ones with no dust seals or will set fire to them ( I did )
Cheers
Ken
Cheers
Ken
2mm paul only wishes he could get an increase like that where he needs it.
:P hehehe
They are cross-drilled? So not much point. I'll have to buy some decent 6pot AP's, don't want to sell me yours?
See'ya:burnout:
crossdrilled for racing is crap.
Stress heat cracks start from the holes and run to the outside very quickly.
In fact I don't know why they cross drill discs?
Cheers
Ken
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
