  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yes i do that all the time haha - ooops accidentally deleted email oh well send it to me again and lll get back to u in another two days.
mmmm hungry!
wonder if the barsted parking inspector has tagged my car yet
yep park outside the building - price for a 1.5 X 2 bit square of bichumon in ridiculous - could almost rent a whole room for what i pay in parking each week.
mmm me thinks just a nice roll of some discription - prawn n salad maybe haha
yeah its quite a change from welshpool where i got "how are ya luv" and everything was battered and fried and u dont look to closely cos you would probably find a big chunk of hair in it haha
subway hehe theres one in warnbro at the shopping centre, or one on elenora drive in rocko off ennis ave opposite bilo
from the uni turn right onto dixon rd, right at the lights onto ennis get in the left lane go through the 1st set of lights turn left at the 2nd set of light and subway is in that bunch of fastfood oulets.
ps: checked with two other performance shops the pressure plate is out of balance, means ripping it out and adding weight, kinda defeats the purpose of a lightened flywheel doesn't it?
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
