  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i didnt enter into the convo your name came up legit and he asked if you were still with kate and i said i didnt even know you had a gf you had said nothing but i'll find out! Thats all go back if u wish my dear. :)
Originally posted by GTS-t VSPEC
Fun=MRGTST not here:bahaha:
We love you Brett, always good to have more whores around.
See'ya:burnout:
hmmm paul uses the word love on another guy. that could confirm a few peoples suspicions paul haha :)
