  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
shitt thats right will n grace is on - i withdraw my previous remark -  damn i was going to watch that.
well I never !!
You would rather watch some crap American in your face , unsubtle , done to death humour than stay on here and have an intellectual discussion about your voyeuristic sex life:D
Hmmm..... on second thoughts , don't answer that.
Cheers
old wine
Ken
voyeuristic sex life? - im a doer not a watcher ken haha.
If u've read previous posts i think you've got enough bad images to last u the rest of ya lifetime - I'll let u have a rest tonight haha Its all Pauls fault he's a bad influence on me (gotta blame the person thats not here to defend themself) :D
I'm a doer and a watcher .lol
What it meant is your sex life and discussions have been up for public scrutiny on these forums for the last...........oh .......200pages.
And stop trying to boost your post count while pwpt60secf is not here to retaliate.:D
Cheers
ken
Originally posted by Sneeza
anyway guys - gotta go .
OHHH SH*TTTTT I left the sprinklers on for like an hour ARRGGHHHHH my dam is going to be DRY!
bye guys!
Dam ???
as in Mundaring dam ??
damn they must be big sprinklers.
Cheers
Ken
my sex life hasnt been up for discussion - i see no recollection on spillin the beans about anything to do with.
Just a few suggestive playful comments being tossed aroung :D
You expect us to work during 9 -5 geez!
In pwpt60secf case ,that isn't the only thing being tossed.:D
Page ownage to the the Niz , the biatch. Damn , missed again:D
Cheers
Ken
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
