  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by adam 32
ken; well only know once the head is off
everyone has told me that number 4 valve screwed = something was dropped. but well have to wait and see
i dont remember anything being loose and altho we may be cowboy mechanics, we aint THAT cowboy
ahhh , youv'e lost me.
I said that if a bolt has gone in , there is nothing your mate will be able to do at your place unless he has valve spring compressor, seat refacing tool and a die grinder so will have to go to a specialist.
Cheers
Ken
you wouldnt believe the quotes i got from workshops though. just for removing and reinstalling the head was $400
I actually thought that was pretty reasonable based on the decent shops charge $65ph these days and it would come with a warranty.
btw
Page ownage again . Hehehe
Cheers
Ken
yeh i wrote that before i read what you posted. im about 1minute behind...
whats the deal with the carbon build up thing?
Engines can get carbon buildup , especially if they have a poor servicing history or are driven sedately.
Changing things can disturb the carbon or a sudden difference in the driving style can shift it.
Ever heard of the freeway tune.
* Sonny , my car won't idle and is running rough *
* no worries Gramps , give us ten minutes*
6K down the freeway in 2nd or third usually solves it.
* that will be $100 thankyou Gramps *
Cheers
Old Lynford Mechanic
Ken
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
