  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hehe... I got this sent to me yesterday.... I though I would post it for a laugh.... see I told you I only post valuable contributions :P
My name came out to be Krusty Bubblesniffer :D
Post your names once you have worked them out too ;)
Children laugh 146 times a day, adults laugh only 4 times a day.....no wonder we're so unhappy... What's your new name???
Sometimes when you have a stressful day or week, you need some silliness to break up the day. Here is your weekly dose...
Follow the instructions to find your new name. The following is an excerpt from a children's book, "Captain Underpants and the Perilous Plot of Professor Poopypants" by Dave Pilkey. The evil Professor forces everyone to assume new names...
Use the third letter of your first name to determine your new first name:
a = poopsie
b = lumpy
c = buttercup
d = gidget
e = crusty
f = greasy
g = fluffy
h = cheeseball
i = chim-chim
j = stinky
k = flunky
l = boobie
m = pinky
n = zippy
o = goober
p = doofus
q = slimy
r = loopy
s = snotty
t = tulefel
u = dorkey
v = squeezit
w = oprah
x = skipper
y = dinky
z = zsa-zsa
Use the second letter of your last name to determine the first half of your new last name:
a = apple
b = toilet
c = giggle
d = burger
e = girdle
f = barf
g = lizard
h = waffle
i = cootie
j = monkey
k = potty
l = liver
m = banana
n = rhino
o = bubble
p = hamster
q = toad
r = gizzard
s = pizza
t = gerbil
u = chicken
v = pickle
w = chuckle
x = tofu
y = gorilla
z = stinker
Use the fourth letter of your last name to determine the second half of your new last name:
a = head
b = mouth
c = face
d = nose
e = tush
f = breath
g = pants
h = shorts
i = lips
j = honker
k = butt
l = brain
m = tushie
n = chunks
o = hiney
p = biscuits
q = toes
r = buns
s = fanny
t = sniffer
u = sprinkles
v = kisser
w = squirt
x = humperdinck
y = brains
z = juice
For example, George W. Bush's new name is Goober Chickenshorts, Tony Blair is Zippy Liverlips and Saddam Hussein is Gidget Chickenfanny!
Now when you SEND THIS ON ... use your new name as the subject. And
If you don't do this, then you are OLD, OLD, OLD and you don't want to have any fun.
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
